This response is not totally on subject.
I agree with Jerry on the use of modified Panhead breathers for Knuckles.
I recently rebuilt a Knuckle engine for a friend, and he wanted me to re-use the original (un-shimmed) style breather valve.*
When I was setting up the cam chest I measured the gap from the nub on the breather to the cam cover. There was a gap of 0.027".
When the pistons go up in the bore, they create a vacuum in the crankcase. This vacuum goes through the gallery at the back of the cases to the breather gear. This *vacuum is timed through a hole in the rotary breather to create a vacuum through the ports in the lifter blocks, lifter tubes, rocker boxes, and finally through the tubes to the base of the valve spring cups, to suck oil out.
Aside from the timed effect that pulls oil from the top end, the vacuum created in the crankcase also pulls the breather gear tightly into the bore until the shoulder of the gear rests hard against the case.*
When the pistons change direction and come down in the bore, they create a pressure charge *in the crank case area.*
This pressure charge would then push the breather away from the case and onto the special landing on the cam cover. This back and forward motion through a 0.027" gap, must cause a clattering noise in the cam chest. *
Shimmed breathers would eliminate this noise.
