1946 spotlights and bar
  • Sidehacker
    • Sep 2012
    • 235
    Im looking for the best copies of 6V spotlights & bar with all the proper wording and insignias. I've seen them on a bike but never found out the manufacturer. I've found a lot with no markings whatsoever. And did the originals ever come in black or have they always been chrome. Thanks FNA
  • Sidehacker
    • Sep 2012
    • 235
    I've been checking back twice a day and will continue to until I find spot lights
    • NiteOwl
      • Jun 2011
      • 247
      Grin, I have been watching your post with much interest as well, as I am also in the market for as good a copy (or real makoy) that I can find for my 42 knuckle. Thanks for putting this post up.
      Bob Beatty
      AMCA 19209
        • 5950
        War production spots were painted black. There is no manufacturers name on them.
          • 4784
          Good luck on copies. I have never seen copies of the long base spots, only the '50 and later short ones. ('49 used long base with pre-focused bulbs, a one year deal).
          As for '46, it is a toss-up as to finish. Early '46 stuff was pretty much blacked out like '45. But some later stuff was chrome.
          • jwl
            • Dec 2001
            • 338
            A few years back I purchased a set from Tedd's V-Twin. They were supposedly licensed by Delco. They were the long stem with the correct markings and no focus screw. I drilled a hole in the back, installed an oval head screw to make them look correct for 41. They turned out real nice. The switches were a little different than originals but the lights were very good copies in my opinion. I don't know if they are still available but you could check.
            • Sidehacker
              • Sep 2012
              • 235
              jwl, I will check with v-twin but I've already looked them over quite thoroughly. I have some old catalogues. Do you have a more exact time frame when you bought those from Tedd's. Thanks FNA
              Chris, were the ones with no markings military or civilian also I should have been more clear on the black ones. Besides when they had no chrome from war shortages, did they ever offer black spotlights on springer front ends. Thanks FNA
              • jwl
                • Dec 2001
                • 338
                I don't remember exactly when it was but probably close to 10 years ago. I am at our winter home now and my receipts are not here. I haven't looked at a V-Twin cataloge for a long time but if you don't see them in a recent cataloge they are probably not available any longer. At the same time I got the spots they also had some cycle rays and generator cutouts that were supposedly licenced by DelcoGM-Guide.
                • len dowe
                  • Oct 2002
                  • 520
                  George @Throttle Masters was selling them not to long ago.
                  AMCA #765
                  • jorrow
                    • Feb 2008
                    • 347
                    Ok, while we are on this subject, I have a pair that has switches but short stems, what years did those fall under?
                    • bobphd
                      • May 2008
                      • 99
                      The imported repop long stem spotlights with markings are vtwin no. 33-0038. Retail for about $200.00 for a pair.
                      Bob
                      • bobphd
                        • May 2008
                        • 99
                        http://www.ebay.com/itm/Early-Guide-...370935993959%2spot lights.jpg
                        • Sidehacker
                          • Sep 2012
                          • 235
                          Thanks bobphd, I already looked at vtwin and called and left message with my rep. She still hasn't got back ahold of me. Usually when I punch it up on there web site it will tell you if it has the correct markings or not. It didn't say anything so that's when I called my dealer rep. Thanks so much . I will order a set ASAP. A friend gave me an original set but they are Pristene and I told him I would use for show only since even the smallest of drops usually wipes out the spots. I plan to ride the piss out of this bike while I can still kick it over so I figured I would get a set of repops to save the originals as long as possible. Thanks to all. FNA. Keith
                          • len dowe
                            • Oct 2002
                            • 520
                            Here ya go..
                            http://www.ebay.com/itm/141103567512...84.m1438.l2649
                            AMCA #765
