Wow! Good job. Your making me hurt for a lathe with an auto center chuck. Or by golly - just a lathe!
Please remember- I know nothing.
Question: Do the shoes contact equally from the cam action? Theoretically they should -shouldn't they? Or do they float and settle in after a bit of use.
Also - I'd think someone with alot of time may already have such a jig. Maybe a racer?
Is the whole thing of cutting the shoe pads way over the top for street riding? Couldn't you just drag them a bit and 80 percent contact good enough? I guess each to there own. Oh well.
How about that first question?
........ I just had to point out the most perfect way of obtaining the best fit.  Used to get *****ed at from my employers for being to accurate!! The way I pointed out will give you the altimate fit and wear possible. Basically a lifetime of never changing brake shoes again!! For that matter your drum would outlast you too. There are easier ways to optain the optimin fits as I explained but a person must have the tooling and the time in the first place to do it. Readouts will eliminate the need to set indicators thus saving hours of time. The best that can be achieved in the conventional way is 50% contact. Usually the contact ends up around 25%.  This is all well and good for most mechanics and I myself settle for this on all of my automobiles but on my until I die personal ride I am a perfectionist. All of these technics work as far a adaquate braking power goes but as I said in the beginning..........if you want 100%......???? do it this way. Disc brakes do the same thing that I have pointed out but they do it from a different angle and with less work to accomplish it. I owe you the beers this time.
