Well I have wasted to much time trying to get it right, maybe I`m too close to it.
Tuning problem with linkert M74. Properly rebuilt. Some engine info.
Stock FL Knuck. (new build)
stock comp. (good comp.)
stock cam
unbaffled exhaust
tappets adjusted properly and then rechecked
Morris H5 magneto
Starts on 2-3 kicks hot or cold
No intake air leaks I`m aware of
idles great
throttles up great at idle (no load)
Champion D16 plugs
I think that should be enough info, low speed screw set correct, set idle low, turn in until rpm becomes unsteady and back out until idle becomes unsteady,
and about back to middle of the two, reset idle.
Problem is the high speed screw is at 3/4 of a turn out. Engine still wants to lug a bit under load, (sputers) got better the futher I turned in the high speed screw.
I hesitate to keep turning it in thinking there is some other reason for it to be in so far. I think about a turn and half out is about right for a starting point
but 3/4 turn out?
Admitedly this is only the second Linkert Ive ever messed with, always shelved them for an s&s carb. but I decided to make a change cause several of my buddies run a linkert with no issues.
So what havent I tried or what can I try. thnx
stock cam
unbaffled exhaust
Morris H5 magneto
idles great
Champion D16 plugs
but 3/4 turn out?
