I have a cam cover that is smooth, cast in baffle plate and a casting # of 25217-40 , the outside oil line hole appears it was welded up before chrome , but its hard to tell , what is this cam cover?
Cam cover help
FROM WHAT I JUST READ , IT SAYS THE 2ND COVER HAD THAT CASTING # IN 54-57 , THEN 3RD VERSION WAS IDENTICAL EXCEPT 5/16 GEN HOLES , THE 4TH VERSION WAS IDENTICAL TO THAT ASIDE FROM SMOOTH AND AN ADDITION OF A OUTSIDE OILER PORT , THEN THE 5TH VERSION WAS IDENTICAL TO THE 4TH EXCEPT NO OUTSIDE OILER PORT . SO IF I READ THAT RIGHT THE 2nd Through the 5th Version all had that casting number , making this a 66-69 cover . Does that make sense?
If nothing else, I guess we hashed it out!! I'd agree that you've got yourself a cover for a generator shovel. I was quick to jump to conclusions and didn't read to the bottom of the page. Wow, we went from '36 all the way to '66...
Cory Othen
Membership#10953
