Correct fork for 1946 ?
  • Eric MATHIEU
    • Sep 2008
    • 70
    I have an early 1946 bullneck frame. It's unclear to me what would be the correct fork to use with this frame. I have heard it would still be the inline style. Can anyone give some insight? Thanks,
    Eric
    Eric MATHIEU @ Beauty of Speed
    www.beautyofspeed.com
  • 46EL
    • Apr 2009
    • 728
    I have seen 2 very original 46 OHV's with Bullnecks and Inline Forks over the last 2 years. 46EL
    • vph-d
      • 1088
      Palmer states the bullneck/inline fork combination was used for approximately 18 to 22 weeks of production.
      VPH-D
        • 2024
        VPH-D
        I do not believe that bullneck/inline fork production in 1946 could be anywhere near "18 to 22 weeks". That is almost half of all 1946 production time. In 30 years of looking at 1946's and trying to answer this question, I have only seen 3 to 4 original bikes with this configuration. Usually the serial number of such a bike is in the 3900 to 4200 range.
        The 29 degree/inline bikes seem to be 1000 to 3900 and the bullneck/offset fork seem to be 4200+. My opinion is that bullneck/inline fork production was a mere transition period and not extended production.
        Jerry
        • MY65HD
          I am here to learn
          • 36
          I was on a cruise once and there were soooooo many forks I just started with the middle one with a "Jethrow Grip"
          • LJH
            • 61
            Hi, I had an early frame, inline- 46, was 37xx s/n Also had a bullneck, offset- 46, was 44xx s/n
            from what, I have looked at in the last 20 years, I agree with Jerrys information
            LJH
            • Eric MATHIEU
              • Sep 2008
              • 70
              Ok so from what I'm getting most 46 bullneck bikes would run offset forks. Thanks for the info,
              Eric
              • knuckleheadtim
                • Jan 2008
                • 141
                In your original post, you state that you have an "early" bullneck frame. If the frame is an early '46 with a 29 degree rake (often called a bullneck), it has to run an inline springer. The true 30 degree bullneck frames used an inline springer for a few months of production, and then went to the offset springer. Make sure you are correctly identifying your frame as a true 30 degree bullneck.
                I just found a picture of a very original looking bike, 46FL49xx, with a bullneck frame and inline springer. Incidently, it has narrow brace fenders, early rocker boxes, and the early flat foot clutch rocker peday.
                  • 5954
                  Here is a factory photo of 46FL1080. It clearly shows the inline fork. I have another photo of a 1946 in the 4000 range that has offset fork.
                  • vph-d
                    • 1088
                    Chris, isn't that bike a WL?
                    Jerry, just parroting what I have read. I'm not as familiar as some of you guys with Knuck nuances.
                    What casting number fork would be correct for a 45FL?
                    VPH-D
                    • 46WL
                      • Feb 2007
                      • 60
                      Yes, that's a WL..
                        • 5954
                        Oops, wrong picture.
