Frame Repair
  • 51FL
    • Nov 2010
    • 207
    Frame Repair
    As some of you know i recently picked up a 47 El , Well i am getting ready to build this thing and i am looking for a us supplier of Race Frames Neck , i have a near Mint Early 42 Frame. The only downside is someone screwed with the neck and lower tank mount so i want to replace those and continue the build .
    • 2044
    Craig Clack? is the US supplier,if he can get anything from Steve and if he can get it thru homeland security
    • tomcat1
      • 115
      this might be old info
      Craig at Tennessee Frame Company as they are our US distributors.
      Email address is tnframecompany@att.net
      Or call cell 931 220 7384 Mon to Fri 8am till 5pm Tennessee time.
      AMCA 26656
      47EL
      47WL
      • Steve Little
        • Apr 2008
        • 915
        Craig has the necks in stock. And he can make re orders at any time.
        US Homeland security department can effect international deliveries by a few days. Especially during times of heightened alerts.
        If you have trouble contacting Craig, I will help you out.
        Regards Steve Little.
        Race Frame Engineering
        Steve Little
        Upper Yarra Valley. Victoria.
        Australia.
        AMCA member 1950
        • Matthew N. Olse
          • May 2007
          • 102
          The 42 frame has a sweated seat post, motor mount, sidecar loops and brake crossover shaft, all of those areas are welded on a 47 frame. If you are going to put a later neck on the 42 frame, then you should address the other areas at the same time.
          A.M.C.A. Board Member
          www.oldbikesinsd.blogspot.com
          www.pre1916scramble.blogspot.com
          • 51FL
            • Nov 2010
            • 207
            Thank you Matt , But i am putting the 42 Frame together as a 42 Frame , So now all i have to do is find a compenent guy to do it .
