I recently bought a pair of 36 to 39 tanks. However, when I attempted to bolt up the shift gate, I found that the front screw hole had been dented in a bit which causes the gate to sit uneven. Any ideas on how to pull out the dent at that site? I thought about bolting down the rear of the gate, heating up the front dent and use a bolt/screw and the front of the gate to pull it out flush. However, I'm not very experienced with these tanks and I'm not sure if that would work. Any ideas/advice are appreciated.
Pulling a dent in 36 to 39 Tanks at Shift Gate bolt
