Sidecar identification
  • montij
    • Jul 2022
    • 138
    Hello, I am trying to find out exactly which application this sidecar frame was for. I can’t make out any numbers on it. I posted this here because I suspect it may be for a JD.
    It is about 19 inches between the mounting plate holes where the leaf springs would go. I don’t see one exactly like this in my parts book.
    The sidecar itself I found a tag on, it’s bottom is rusted out completely and I’m hoping to weld in steel and use this setup on my 31 VL eventually.
    thanks
    This gallery has 5 photos.
    Justin Monti
    AMCA #43973
    • 4789
    JD mounts and the tag appears to be for a 25LT, a standard width J Series sidecar.
    • Tommo
      • Sep 2001
      • 1320
      You should be able to find the chassis numbers on top of the axle tube about 4 to 5 inches in from the rear mounting.
      Here's 3 of mine that should give you some idea IMG_20240629_0001.jpg IMG_20240629_0003.jpg IMG_20240629_0002.jpgThe first L denotes a lefthand side fitting sidecar chassis. American chassis numbers will just start with the year numerals.
      Peter Thomson, a.k.a. Tommo
      A.M.C.A. # 2777
      • MMasa
        • 1192
        Your chassis looks like the wide two person style in the pics.
        Mark Masa
        www.linkcycles.com
