M88 for 25J
  • aumick10
    • Nov 2018
    • 465
    M88 for 25J
    I have a M88 that i want to run on a 25J. My question is do i need to use any fixed jets in this arrangement, or just block of both jet locations.
    Cheers
    • 4789
    Block them off and use the low and high speed needles for adjustment. Change the high speed to the type used on an M-51 or other 1-1/4" carb.
    • aumick10
      • Nov 2018
      • 465
      Thanks Rubone, Do the 1 1/4" needles have different angles or just different length?
        • 4789
        Using the standard 1-1/4 needle just replaces the short one and the lock plug used on M88 making adjustment simple. An M88 is a 1-1/4 carb with military spec needle so riders could not adjust it.
