28' JD Leaking oil tube above engine
  • moto1969
    • Nov 2014
    • 66
    My 1928 JD is leaking oil from this area and onto exhaust. Two wrenches barely fit to tighten the nuts. Is there a rubber seal or other seal that has failed that needs to be replace? I don't want to strip the threads.
    I would check the oil level in the crankcases first. Any more than say 8 ounces and oil will come out at the weakest point.
    • knucklehead 61
      • Sep 2016
      • 350
      that is a typical leak on a jd. there are no seals on the adapter fitting nor the tube nut, however you can always put some thread sealant on the threads to attempt to lessen the leaking.
      • moto1969
        • Nov 2014
        • 66
        Thanks for responding, I overfilled the crankcase with oil and have since drained the oil. I have added the proper amount of oil.
