Clutch house bearings
  • Stein.S
    • Sep 2021
    • 57
    When clutch house was removed the parts from bearings fell out. Have no idea how they were placed. Pretty sure the inner bearing is placed right, but how is the thin shim and the outer bearing supposed to be mounted?
    Best regards, Stein-S
    This gallery has 1 photos.
    • 2174
    Dear Stein, you are nearly there. Someone has put in two rows of the short 304-15 rollers when you should have one row of the 305-15 long rollers. As for the crankpin, the cages should face each other with the long rollers in between,
    • Stein.S
      • Sep 2021
      • 57
      Hi. Thank you for answering my question. Will order the right bearing.
      best regards, Stein-S
