Originally posted by jdonaldson
View Post
It looks pretty smooth, and you need a real pivotnut/screw to prevent damage...
The HXs used one with a .406" shank;
(DLXs and cork-float Linkerts used a .359" shank. Somewhere around 1950, the "Armstrong" floats were introduced with a return to the .406" shank,)
The hex is retained in the notch upon the bottom of the float, and the screw should then squeeze the float slightly before the lever bottoms out firmly upon the shank.
If your float weighs more like nine grams than three, it alone is enough to cause grief.
Does it only drool when the petcock is open?
PS: Please feel free to email me direct at Liberty@npoint.net...
