1912 Harley Single Project
  • MMasa
    • 1192
    I’m in need of a few bits for a 1912 Harley single I’m working on.
    For the engine I need the complete intake valve housing. The screw in valve housing, valve, valve cap, etc. I believe that this is the same as on a 1910 and 1911.
    I also need the decompression lever on the outside of the motor.
    I could also use either a complete motor pulley or at least the outer plate.
    For the chassis, I need the pedal crank and crank sprocket and (long shot here) front and rear fenders.
    Any help would be greatly appreciated.
    Mark Masa
    Mark Masa
    www.linkcycles.com
  • brettxlch
    • Jan 2019
    • 141
    Mark send us a few pix, i for one would luv to see your progress, biker buddy...
