1919 Harley F
  • Nick Roud
    • Jan 2020
    • 2
    1919 Harley F
    I have been building a Harley F basket case and now working on the spiral twistgrips can someone please tell me how i secure the single cable in the steel slider that goes inside the handlebars, i have a small threaded piece that screws into the back of the steel slider but not sure if you solder it or just bend it .
    Nick
  • slamiste
    • Mar 2010
    • 260
    Nick,
    Part number 3322-09 is the wire fastening screw that screws into the back of the slider. You also need part number 3324-09 control wire end. The control wire goes through the wire end and is bent over into a slot in the back side. See the following pictures. If you're missing the control wire end I believe HD used this part number well into the 40's. It's usually sold as part of the inner control wire. 001.jpg002.jpg004.jpg
    Steve Slaminko
    • Peter Cooke
      • Aug 2012
      • 563
      Colony sells a kit with all the required items.
      • Nick Roud
        • Jan 2020
        • 2
        Many thanks for the help i now understand i have all the parts just needed that information
        Nick
