Fork ?
  • Juha_Lahtinen
    • Apr 2019
    • 27
    Fork ?
    Hello i am build up jd 28
    But the fork what i have it does not fit.
    Rear fork is type number kc-15D and front fork kc20d
    So question from what type hd these are?
    These are in good shape if someone like to swap..
  • MMasa
    • 1192
    It may be the 1922-23 74" / 1924 61"and 74" version.
    What's the distance from the underside of the bottom crown plate to the centerline of the rocker stud hole?
    Mark
    Mark Masa
    www.linkcycles.com
    • Juha_Lahtinen
      • Apr 2019
      • 27
      Mark
      Thank you Mark!
      These are like this. 1inch =2,54cm
      What are these
      • Juha_Lahtinen
        • Apr 2019
        • 27
        Better picture
          If your tape is right they are both early forks 1922-24
          • Juha_Lahtinen
            • Apr 2019
            • 27
            Thanks .. what type of harley these are from?
            Is there any who are intrested to swap to 26-29 jd forks
            Br Juha
            • 46EL
              • Apr 2009
              • 728
              Br Juha
              I can't use your Forks but I do have a rear leg and leg only for the late fork that uses a front brake for $450.
              I was told it is for the late 20's??? USA UPS Ground Shipping only please. 46EL
              • Juha_Lahtinen
                • Apr 2019
                • 27
                Hey thanks i am intrested . Can you send picture. Glimsradio(ad)gmail.com
                • Juha_Lahtinen
                  • Apr 2019
                  • 27
                  I am travelling monthly in usa so shipment is not problem..
                  • MMasa
                    • 1192
                    Your rear leg is correct for 1922-1923 74" as well as 1924 61" and 74"
                    Mark
                    Mark Masa
                    www.linkcycles.com
                    • Juha_Lahtinen
                      • Apr 2019
                      • 27
                      Thank you Mark?
                      If some one is intrested let me know.
                      This is my jd 1928 project.
                      • Juha_Lahtinen
                        • Apr 2019
                        • 27
                        Still open for fork offer.. no deal yet.. i am from europe but I do have contacts to usa + shipment address in usa is ok.
                        Thanks Juha
