Question regarding seat removal from 1925 frame
  • Sasha
    • Feb 2019
    • 19
    Here is the photo , what is the proper removal procedure ? Is this seat post secured from bottom? I was under impression that it will have adjusting nut some place or is it one height fits all type IMG_5869.jpgIMG_5868.jpg
    • 2024
    The nut that would have held the seat post in is missing (2nd photo). It is not uncommon for the seat post to stuck quite firmly in the seat tube especially on bikes that have been out in the weather. Removed a few stuck ones in my day and have at times used heat or porta-powers to get them out.
    Jerry
    Originally posted by Sasha View Post
    Here is the photo , what is the proper removal procedure ? Is this seat post secured from bottom? I was under impression that it will have adjusting nut some place or is it one height fits all type [ATTACH=CONFIG]24676[/ATTACH][ATTACH=CONFIG]24677[/ATTACH]
      • 2024
      The height adjusting nut is inside the frame above that nut that is missing.
      Jerry
      • Sasha
        • Feb 2019
        • 19
        Thanks Jerry ,
        Is it very bottom of the seat tube were is missing nut located ? Do i use heat and solvent to that section and try to push it upward ?
        • HDSmitty
          • Jul 2017
          • 282
          There was a nut on the exposed end that has now been cut off. I would load it up with your preferred penetrant and it looks like you could use a puller of some sort to pull the frame off while pushing out the remaining post. If it doesn't come right out, (I wouldn't expect it to), at least you could leave pressure on it while the penetrant does its thing. Give a turn or 2 on the puller every day to maintain pressure until you achieve the desired result. Patience! Good luck, hope this helps. Smitty
            • 6029
            You are going to bust your ass getting that seat post out. Everyone has been there, and everyone has a tale to tell about how they got their seat post out
              I would under bore it with an angular cutter bit at both ends, I'd have that thing out of there faster than you could spin your head. I love it when the engineers step up to the plate here. Thank god you don't work for me. Bob Luland
              • Steve Swan
                Possessed by Motorcycles
                • Aug 2013
                • 1589
                Indeed, a potentially nasty and challenging situation to be in! Applying continual pressure over time combined with occasional heat with patience and perseverance will prevail. Making up a screw puller inside a tube that will seat against the top of the frame tube as pressure is applied to the seat post likely will effect the possibility of moving the post. that or a substantial slide hammer, but imho, consistently applied pressure of a puller is the best bet.
                Steve Swan
                27JD 11090 Restored
                27JD 13514 aka "Frank"
                  • 6029
                  If you're talking to me, Bob, I don't have an annular cutter (let alone the right size), and a Bridgeport mill to put it in. Most guys have the basic hand tools, maybe a drill press, and a lot of ambition. I based my comment on what most people have in their home shop.
                  • Sasha
                    • Feb 2019
                    • 19
                    I will take my time and let you guys know it goes. I know it is going to be a challenge with the tools I have or do not have but will give it my best. Thanks for tips !
                    • Steve Swan
                      • Aug 2013
                      • 1589
                      Bob, your post is why i send stuff to you i don't have equipment or skills for.
                      Steve Swan
                      27JD 11090 Restored
                        I was kidding around. Eric if you can get that frame in my milling machine? Your a better man than I'll ever be. Let's cut to the chase. You got a rod stuck in a bushing. So what do you do? Sit there for the next two week whacking this thing while feed it over price ATF or is there an easier way. If I were in a garage with limited means. This how I would get that thing out. If the end of the rod is not flat. Make it flat with a round burr in a hand drill. You now need to fabricate a centering bushing (I've seen cheap kits of these on the internet). This is nothing more than a piece of round stock to sit in the hole with another hole in the center for a transfer punch. The whole idea here is to put a center make on the rod (If you try to do this by eye, you will fail). Once you got that covered being the most important part of this job. You can ether drill the thing out in steps or use a an angular cutter. The picture is of a kit made by Rotobroach I carry on my dashboard for making hole in stuff in the field. The kit is #11090. You can find them on Fleese-bay for around $40.00. If ya drill a 1/8" hole in the rod. You just use the centering pilot pin that comes with the kit. These cutters are incredible. You can get them up to two inches long. I hope this helps somebody out. ATF and praying just don't cut it. Bob L
                          • 6029
                          I know you have recommended those cutters in the past for sheet metal work, Bob. I guess it's time to let a few moths out of my wallet and get a set. I didn't mean to put you on the spot.
