i will appreciate someone telling me what the distances are between pivot points for the 1927 JD rigid fork and the spring fork. mine are slightly tweaked.
Re: 1927 front forks
27JD 11090 Restored
27JD 13514 aka "Frank"
https://www.youtube.com/watch?v=bwlIsZKmsTYTags: None
Steve
I'm not 100% sure what dimensions you're looking for. Do you mean the inside width between the legs where the rocker studs attach?
MarkMark Masa
www.linkcycles.com
Yes, sir! Those are the 2 dimensions i am in need of! Thank you for asking!Originally posted by Steve Swan View Posti will appreciate someone telling me what the distances are between pivot points for the 1927 JD rigid fork and the spring fork. mine are slightly tweaked.Steve Swan
27JD 11090 Restored
