Serial number question
  • Mike Dix
    • Feb 2019
    • 13
    I have a project 29 JD . The engine case is stamped 29 JC . What does the “C” stand for ? I’ve been told commercial ? Maybe the stamper was moonlighting at Miller Brewing Co.
  • MMasa
    • 1192
    You were told correct information. C = commercial
    Mark have been a package truck, etc.
    A JC would be a 61", low compression, generator equipped, and probably with a large rear wheel sprocket.
    Is it a JC or a JDC? (61" vs 74")
    Mark
    Mark Masa
    www.linkcycles.com
    • Mike Dix
      • Feb 2019
      • 13
      It is a JC . So I have a 61”. I’ll check the rear sprocket also. I’ve done many projects and they have all been assembled when I bought them so I could take a bunch of pictures through the disassembly. This one is in box’s and I’m finding I have a challenge on my hands . Loving every minute of it! Thanks
      • MMasa
        • 1192
        Well, the VIN indicates that it's a 61" but all you have to do on 1924 and up cases is use 74" flywheels, cylinders, and a few other small bits and it's a 74"
        Mark
        Mark Masa
        www.linkcycles.com
        • aumick10
          • Nov 2018
          • 465
          Is there a difference between the 61" and 74" rod lengths?
          • MMasa
            • 1192
            Not from 24 or 25 up. I'd have to look in my notes to verify which year.
            There were 74" specific rods for early 74's. 1921-24? non DCA motors.
            Mark Masa
            www.linkcycles.com
