I will certainly appreciate being told the type of bulbs i need for each socket for the original '27 Twin headlight. i suspect each bulb is a single element. Thanks in advance.
Re: Bulb types for original 1927 Twin headlight
27JD 11090 Restored
27JD 13514 aka "Frank"
https://www.youtube.com/watch?v=bwlIsZKmsTYTags: None
My parts books shows PN# 4925-29 for a 2 pin, 2 element bulb (2 reqd.). Of course that part number is pretty much useless today, but I suspect it's the same bulb as you would find in a tail light. You know twin headlights were only used in 1929, and 1930.Eric Smith
Thanks Eric. Yes, i saw those pn's in my book as well. with the help of a couple members i was able to figure out what bulbs were originally used and sources for the bulbs. the large double contact bulb is an 1134, and the dimmer bulb is a #81. the 1134 is 32 candlepower, and i believe the #81 is 6 candle power. i got some original Tung-Sol 1134's off ebay, and the # 81's are widely available. The # 81, being 6 candlepower, and what came from the factory, and same as the tail light bulb, i cannot imagine being much good for seeing much of anything at night. on Bratton's website i found 50 candle power double contact bulbs, and for single contact i found 32, 21 and 10 candlepower bulbs, which i ordered a couple of each. i thought i would experiment with the different bulbs to see how much current they draw. i do not know how any of these bulbs will perform in contrast to the bulb that came with the Polish repro headlight i currently am running. what i do know running the current head/taillight setup, is the ammeter reads 5 amps when i am riding underway with no lights on, and maybe a half amp with lights on.so, it will be interesting, after i've mounted my original headlight to see what a 32 candlepower bulb actually draws, and then maybe i can go from there in terms of using higher candlepower bulbs fore and aft. Anyway, this is waht i have learned so far, so we shall see what else i can learn as my converting to original lighting evolves.Originally posted by exeric View PostMy parts books shows PN# 4925-29 for a 2 pin, 2 element bulb (2 reqd.). Of course that part number is pretty much useless today, but I suspect it's the same bulb as you would find in a tail light. You know twin headlights were only used in 1929, and 1930.Steve Swan
27JD 11090 Restored
Steve, These charts have helped me in the past with bulbs. WilliamWilliam Edwards, AMCA #10035
William, thank you for those charts, i shall download them into my JD files!Originally posted by wideglide38 View PostSteve, These charts have helped me in the past with bulbs. WilliamSteve Swan
27JD 11090 Restored
