Hi Can anyone put up a picture of a 1924 JD heel brake pedal please, I need one and plan to make but can't find a good picture Thanks
24JD heel brake pedal
This is just the heel brake pedal assembly. The rear brake backing plate is different than the early hand brake type, as well as the actuating lever. I used to have the complete heel brake assembly, and may still have a few parts left. I do not have the pedal.Eric Smith
That's the 1921/22 heel pedal and this is the 23/24 one.
Very subtle differences which may or may not cause problems if the wrong one is fitted.Attached FilesPeter Thomson, a.k.a. Tommo
A.M.C.A. # 2777
Zig1
I have one. While it's not for sale, I'd be more than happy to make you a tracing and mark it up with other dimensional info so that you can make one.
Does Competition still sell the cast pedal flip bits?
With one of those flips in hand, it would be relatively easy to make the rest of the pedal.
PM me with your email address.
MarkMark Masa
www.linkcycles.com
