Well I did it - bought another one.
    • 2024
    I believe it is a 1923 by the number near the seatpost. I also got the transmission for it but nothing else. Came from a friend who got it out of a shed in southern Minnesota.
  • gww
    • Dec 2011
    • 143
    looks like a great foundation. you guys good we hope.
    gww57.com
    • MMasa
      • 1192
      Jerry
      Looks like a 23 rear fender to me. With that wide fork and front fender the engine should be a 74" and NOT a 61" unless you're just building a rider.
      Everything looks to be in really solid condition. Good score.
      Mark
      Mark Masa
      www.linkcycles.com
        • 2024
        Yes Gary - Debi and I are good. Hope the best for you and Linda too. We are going to be on the Colorado Road Run in June out of Blackhawk. You going to be around?
        Jerry
          • 2024
          Mark I was wondering about that wide frontend. I was thinking that maybe it was just a later front but everything looks so undisturbed. I do not see a restoration out of it but Cannonball did cross my mind. I would be looking for an engine if one was out there.
          Jerry
          Originally posted by MMasa View Post
          Jerry
          Mark
          • MMasa
            • 1192
            Jerry
            In 1922 and 1923, the 74" used the wide fork and front fender without divots in the valence while the 61" used the earlier -16 rear leg and a wide fender with divots in the valences to fit the narrow fork.
            Sent u a PM.
            Mark
            Mark Masa
            www.linkcycles.com
            • gww
              • Dec 2011
              • 143
              we will be there. look n forward to catch n up.
              gww57.com
              • Steve Swan
                Possessed by Motorcycles
                • Aug 2013
                • 1589
                wow, that chassis looks to be a beauty !
                Steve Swan
                27JD 11090 Restored
                27JD 13514 aka "Frank"
                  • 2024
                  Yeah Steve it looks real solid. With any luck the frame won't need anywhere near the work my last Cannonball bike did.
                    • 2024
                    Mark This is a picture of what I have. I need everything else. Does the number on the frame correspond in any way to the serial number that would have been on the engine? Jerry
                    • MMasa
                      • 1192
                      Ok Jerry, know what you need now.
                      If you are going for correctness and your frame is marked 23F xxxx, then the trans should have a letter L and while the serial numbers between the engine, frame, and transmission do not match, they tend to be somewhat close. In the neighborhood of within 100 to 500 of each other.
                      Mark
                      Mark Masa
                      www.linkcycles.com
                        • 2024
                        Mark
                        I doubt that I am going to go that much for correctness -- I do not have that much time or money. I was just curious more than anything.
                        Mark
                        • MMasa
                          • 1192
                          Jerry
                          I sent you an email but I'm not sure if I have ur current one. If you didn't get it, pm me with a correct one.
                          Mark
                          Mark Masa
                          www.linkcycles.com
                          • JoJo357
                            • Feb 2016
                            • 3296
                            Hello Jerry, nice score--if you're just building a rider, i have an early 20's J Motor and most of the trans/clutch laying around doing nothing. *M.A.D*
                              • 2024
                              JoJo Thanks for the reply but I think I would like to stick with q 23/24 engine. I've got time and I will keep it in mind. Most of the JD stuff I own is 25 and newer but some would work.
