J/jd valve clearance specs.
  • 46CHF
    • Nov 2009
    • 67
    Rebuilding 1915 61 inch top end what kind of valve stem clearances are run on these motors and on the stepped exhaust valve stems are both diameters sized or is the larger diameter just clearance and if clearance what is acceptable. Any help here would be greatly appreciated
