Plunger Guide Tube
  • Caperodder
    • Aug 2014
    • 26
    Plunger Guide Tube
    Hello,
    Been trying to remove the Plunger Guide Tube on a 19. Got it to move about 1/4" or so. Is this just press fit? I put a wedge in the frame tubes to open them up a bit, applied some heat. Still no-go.
    Don't want to break anything.
    Thanks.
  • MMasa
    • 1192
    The diameter of the guide tube gets smaller about 2" down. Try spreading the frame a touch more. It's just a slip fit into the frame and is only held at the top. Never fear, if you end up destroying the guide tube, I make and sell them.
    Mark Masa
    Mark Masa
    www.linkcycles.com
    • Caperodder
      • Aug 2014
      • 26
      Perfect.
      Thank you.
