Harley J 61 inch Exhaust Valves
  • TechNoir
    • Dec 2015
    • 301
    Hello folks, some of you may know that I need new valves with oversize stems for my 20F.
    I have been looking at options and have ruled out new valves from a well known J & JD supplier due to quality concerns.
    There are some valves for various diggers that I could modify but that would leave the stem needed to be surface treated if it is to be used in iron guides. Therefore I have looked at getting some valves made.
    The short story is that the first 2 valves are quite expensive but then the price drops off a cliff for subsequent valves.
    This may be more of interest to my UK and European colleagues but does anyone else want any exhaust valves for a 61" J or F?
    John
  • ChrisLewis
    • Aug 2015
    • 82
    John
    I have replaced my whole top end on a 27J with new from JD Jugs including the valves, I think the old ones where ok, give me a call on 07967561743 (Portsmouth England) regards Chris
    • ChrisLewis
      • Aug 2015
      • 82
      Reference valve guides look on Antiquebike web site (no additional vat from Europe !)
      • TechNoir
        • Dec 2015
        • 301
        Re: Harley J 61 inch Exhaust Valves
        Chris, thanks for the reply. The valves that I have are fine, its the guides that are shot. The standard valves have 0.310" stems and so I was after oversize stems so I could ream out the old guides to suit.
        Are your old valves standard stems or oversize?
        I have probably changed plans now following some comments on the Yahoo group and I think I will be modifying the guides to take replaceable guides.
        John
