JD compression rates
  • otis71
    • Jul 2015
    • 597
    I know there are many variables and I don't know what internals are in my JD but can anyone tell me the normal compression rates for the JD? Mine started running bad and when checked I got 25 psi out of the rear cylinder and only 15 psi out of the front cylinder.
  • harleytoprock
    • Apr 2003
    • 374
    Sounds very low. You should have at least 75 psi. Confirm your guage accuracy.
    • dlm32
      • Jul 2009
      • 110
      My racer, runs about 55 to 60 lbs warm, with an original iron piston/rings and tapered bore, since I built it about 5 year ago. Try lapping the valves, and the intake housing.
      David Morrill
      Sylacauga, AL. USA.
      AMCA #15284
      Deadly Dave's Blog
      Sharing the Lost Stories of Early American Motorcycling.
      http://dlmracing.blogspot.com/
      1921 Harley-Davidson Model J Racer
      It will break a hundred, if you drop it from a plane!
