Engine temperature
  • otis71
    • Jul 2015
    • 597
    Engine temperature
    Having just getting my barn find 26 JD operable I was just wondering approximate top end temperature. It seems to be about 220 after a short run. The plugs look good and I'm using straight 50 weight oil. Is this normal? Should I go up to 60 weight?
    • 8239
    Golly Gee, Otis!
    Do you think a "short run" has it up to equilibrium?
    Here's some relative temps from a smaller flatty (attached).
    Reading temps from the outside of the motor may be quite deceptive,
    And beware that heavier oil holds more heat. Its more dense.
    Good luck!
    • DanM
      • May 2005
      • 465
      Otis- where did you measure and how? Did you use a thermal gun?
      Dan Margolien
      Www.yankeechapter.org
      Pocketvalve@gmail.com
      • otis71
        • Jul 2015
        • 597
        I checked the temperature behind the inlet valve, feeling it was very hot it concerned me. I have since realized idling it heats up extremely fast and as soon as it gets air over it the temperature drops quickly. Rather be
        • otis71
          • Jul 2015
          • 597
          Rather be cautious than learn by failure.
