J Model Inlet Housings/Rocker Towers
  • MikeW
    • Apr 2015
    • 149
    A quick question which may have been addressed before, though I can't find the Forum Thread.
    I'm starting the assembly of the motor of my 21F restoration, but am unsure which of the two types of inlet housings, (photos attached) to use: the type with the narrower opening at the top and the casting number DA743 on the side of one of the rocker support arms; or the later type with the wider mouth and the casting number DA743A on the body of the housing.
    I think that the former was used up through 1922, and the latter from 1923 when the heavier, conical, inlet valve springs were introduced, but I don't have any documentation, and would be happy to stand corrected. Any advice or info gratefully received as always.
  • MMasa
    • 1192
    MikeW
    You are correct. The narrow hole is correct for your 1921.
    You are also 100% correct regarding the reason. The -23 conical springs need more room.
    Mark Masa
    Mark Masa
    www.linkcycles.com
    • MikeW
      • Apr 2015
      • 149
      Thank you Mark, as always. That has to be close to a record for a response to a query - 25 minutes!
