Changing Tires
  • danf19
    • Apr 2013
    • 246
    Changing Tires
    I recently purchased a few tires and tubes to get some of my motorcycles rolling. This would include a Harley JD and VL. I have 2 tire irons. I am having a heck of a time trying to put the tires and tubes on the rims. I checked you tube for a few videos on doing this correctly but not seeing one that's really applicable. Anyone have a video recommendation, tools or "tricks" of the trade they can share with me ?
  • painterdale
    • Oct 2013
    • 423
    I'm fortunate enough to be able to throw them in the spray booth on the bake cycle. A bit of heat goes a long way. My clinchers rolled on by hand with a little soap. Kinda scary when you think they could roll off just as easy! Dale
      • 6029
      As Dale said, the clinchers should go on by hand, without using tools. Here in Florida, it doesn't take the sun very long to make rubber pliable. Also, put some air in the tubes to minimize pinching them when you're working the tire on the rim. A clincher tire relies on air pressure to keep it on the rim, so always check your tire pressure before going for a ride.
      Your VL tires have a safety bead so they could be harder to put on the rim and you will probably need your tire irons. I have a piece of leather that I use to protect the painted rim from the tire tools. I have also heard that a good motorcycle shop can put tires on without hurting painted rims. If you have such a shop in your area, it would probably be worth the money to let them do it.
        • 4789
        Several things to keep in mind with drop centers (VL). Slightly inflate the tube, so it has a bit of shape but does not inflate the tire. Use plenty of tire lube, Murphy's oil soap works well, dish washing liquid too. Insert one edge of the tire into the lowest point of the bead. You should be able to almost (all the way with practice) roll the edge over the rim. Insert the tube int the half mounted tire and install the valve stem in the hole but don't pull it down all the way ( you can use tube talc if you like). Install the second edge in the deepest part of the drop OPPOSITE the valve stem. Keep the opposite in mind, it is important. Then with the tire generously lubed start working it into place keeping the edge pushed up into the deep part (be sure the tube is clear and inflated enough to keep its shape but NOT interfere with the tire). Tire irons are usually only needed for the last few inches at the stem position, and rim protectors can be almost anything. Like cardboard from a cereal box. If you are using lots of force you are doing it wrong. Double check that the tire is in the rim drop. Once the tire is in place make sure the tube nipple is correctly aligned , and inflate the tire with the without the tube core installed. After the tire seats remove the chuck and let the air back out. Install the core and re-inflate. This allows the tube to move around and not be stressed. When I was working in shops against flat rate I could change tires with just lube and my hands on smaller tires, and spoons on bigger ones in very short time. My tire spoons are truck type though, not skimpy bike ones.It paid well...
        Spoons in the foreground.
        • Jim
          • Sep 2001
          • 789
          When I put the tires onto my VL rims, I would soap up the bead slightly, and then "slam" the rim into the one side of the tire. Then, I would hit the bead with a rubber mallet. Then, put in my tube, and push down on the tire to get as much of the tire onto the rim as possible. Then... finish the install by using the rubber mallet.
          Jim
          AMCA #6520
            • 8239
            Beware Folks,
            Some dishwashing detergents are quite corrosive.
            I keep my tire machine a secret.
              • 6029
              I think you're right Tom. I have a friend that used JOY on an all white clincher years ago, and he believes that caused the surface to craze. Like Robbie suggested; look for Murphy's tire soap.
                • 8239
                Eric!
                I got my Murphy's Oil Soap from my local dumpster.
                Haven't used it yet, but its a lifetime supply, because the tire machine is a secret.
                (And nobody knows how to use it but me.)
                PS: I regret and apologize for ever suggesting dish detergent for bubble-testing manifolds, without stressing a rinse.
                • Jim
                  • Sep 2001
                  • 789
                  I NEVER knew that about using dish detergents.... Thanks for that info!!!
                  Jim
                  AMCA #6520
                  • danf19
                    • Apr 2013
                    • 246
                    Guys:
                    thanks for all the help. Lots of good ideas. The heat and the soapy water were a big help. also, on the VL rims making sure the side opposite of the side of the tire you are trying to get on the rim is all the way down touching the innermost part of the rim which allowed slack on the other side - make sense ?.
                    thanks again,
                    Dan
                      • 4789
                      Just as I said in my post...
                      • Jim
                        • Sep 2001
                        • 789
                        Found a YOUTUBE video on what I was talking about when you use a rubber mallet. This is NOT my video or me... but the method is the same as what I do.
                        Jim
                        AMCA #6520
                        • frichie68
                          Senior Discount
                          • Apr 2012
                          • 646
                          https://www.youtube.com/watch?v=wP1su9riLkc
                          Way too easy! Interesting that there are several different methods. I use a ratchet tie-down around a tubeless tire to spread the tire to meet the rim on the first inflation.
                          Rich Inmate #7084
                            • 8239
                            On the side of the road, Folks,...
                            There's nothing like a "Breezer."
                            (Somebody "borrowed" mine... This one was a gift from a good friend at D-port.)
                            PS: If anybody finds a veteran with the handle bored out to hold a patch kit, I want it back.
                            PPS: A racing kickstand makes a good toolbag hammer.
                              • 4789
                              Hammer and tire spoon in one....
