JD Engine Sprocket/ Nut
  • rusthobo
    • Oct 2012
    • 1
    Just putting a new sprocket back on my 29 JD. In looking at the parts book it does not show any lock washer that I can see for the sprocket nut. Is this correct? On the JD's, do you just tighten up the sprocket nut? Does anyone use a lock washer of some type or locktite or?? Thanks in advance.
    No lock washer. Just brutal tightening and some blue Lok-Tite. Make sure ya clean the threads with lacquer thinner inside and out. Bob L
