'17 Mag Twin Control Sleeves?
  • jdonaldson
    • May 2012
    • 29
    Well I finally got the motor mounted into the frame and now I'm trying to tie it all together. I see that Competition Dist. sells an Intermediate Control Sleeve (their p/n 3371-10A (HD #AK156) for '10-'17 Singles. My question is whether or not there is a significant difference between this and the part for my twin, which is not listed. Again, any help or hints is much appreciated.
    Jim Donaldson
  • MMasa
    • 1192
    Jim
    I think that the main difference between that one and the one that you need is the direction that the cast head at the end points. I believe that they are opposite hand from each other.
    Mark
    Mark Masa
    www.linkcycles.com
    • jdonaldson
      • May 2012
      • 29
      Mark,
      Thanks for that info. Now 2 more questions ..... they sell a carburetor control sleeve for the '17 mag twin which looks to be a mirror image of the intermediate control sleeve for the single. Not seeing one of these in the flesh before I'm wondering if the carb sleeve be used in both places? Failing that, do you know of any other source for these?
      Jim
      • Tommo
        • Sep 2001
        • 1320
        P.M. me please exactly what you want.
        I'm sure I can supply all the bits you want with NOS HD parts
        p.j.thomson@actrix.co.nz
        Peter Thomson, a.k.a. Tommo
        A.M.C.A. # 2777
