24-29 Cylinders
  • MikeW
    • Apr 2015
    • 149
    24-29 Cylinders
    I'm sorting through my surplus parts and have these two cylinders which I believe are for 24-29 J Model H/Ds. Stud holes are at 3 1/4 inch centres (pre-24 is 3 I/8?). Don't think they were originally a pair as the rear cylinder has noticeably more nickel remaining than the front one. Also, though I don't have a micrometer to check the bores, the rear seems to have a bit more "meat" left than the front - perhaps the original bore. The front doesn't appear to have any broken fins; rear has two.
    As I don't know much about post-23 models, and whether there were any subtle variations in cylinder castings between 24 and 29, I'm simply looking for confirmation that I have got the id right. (I've apparently got the camera to focus on the background rather than the cylinders but they should be clear enough for identification.)
    I'll shortly post a photo in the "Other Harley" section of the forum of what I believe is a cylinder for a single.
    I'd also be grateful if anyone can offer a view on my earlier post about inlet manifolds
    MikeW
  • MMasa
    • 1192
    Mike
    I would date them as 1925-1926 cylinders.
    They are large base as you say, so that puts them 1924 and later.
    They both still have a 7/8" spark plug hole so they are pre-1927.
    Lastly, the top radial fins that face the center of the motor all slant downward. This is a 1925 and up feature to clear the new style top motor mounts.
    Are they for sale?
    I'd be interested in them.
    PM me if they are.
    Mark
    Mark Masa
    www.linkcycles.com
    • dakotadave
      • Jan 2016
      • 4
      are these off a 1929 jd? I'm restoring a 1929jd and need a engine, transmission, carb, horn, luggage rack, Do you have any parts?
      • MikeW
        • Apr 2015
        • 149
        Hi Dave.. The cylinders are 61 ci (J not JD) and in any case, according to Mark Masa (see previous posts), are 24/25 rather than 29. While I'd help if I could, I'm sorry to say that the few spare parts I have left, after swapping to build up enough parts for my 21F and 23F projects, are in the 18-23 range rather than the late 20s. But best of luck with the search and the restoration for the 29JD - the last of the F Heads I believe?
        Regards, Mike
