I was changing the chains on my 1915 Harley three speed. I rotated the back wheel by hand and noticed the clutch drum has side to side wobble in it as it rotates. I have a couple of questions that may not be easy to answer in a post. I took a short video, but it is 26MB and it does not look like there is an easy way to attach it directly to this post without some type of video hosting account (which I do not have).
1. I have the Directory of Spare Parts, but it does not show clutch disassembly or stackup. Can someone point me to some documentation that show the process to remove the clutch components and then the drum that holds these parts?
2. Can this be done with the transmission in the bike, or does it need to come out and done on the bench.
3. Once everything is reassembled, what is the process for adjustment.
4. Is clutch drum wobble normal, or is this the symptom of a worn bearing or other typical problem.
5. Any special tools needed?
Info is a little scarce. Even some photos showing how things come apart would be helpful.
