The cases are A18T 182## We know there were only 61'' motor's in 1918. My front cylinder is 3.314 inside the bore. 5 fins on the exhaust port. The problem is the bolt pattern is about 1/4 hole off all the way around the bass and the spiggit is about .050 to big to drop down . Life time with shovels first time with J type.
need help. My cylinder won't fit my case.
You have a large bolt pattern 61" cylinder used 1924-1929.
email me at mark@linkcycles.com with pictures of your cylinders. I may be able to help you out with the proper cylinders.
Mark MasaMark Masa
www.linkcycles.com
Thanks for the information. I took the cylinders and chucked them up by the inside bore with a three jaw chuck and put a steady rest on the cylinder plug. Then turned the spigget down to 3.550 I also had to slot the holes out just a little. The cylinder had to have the a repair around the intake housing cap ,Spark plug hole and some fins welded back on. All with nickel rod. I don't think I hurt any thing since it could not be used in a restoration anyway. If you have any cams left I'll need one later on.Originally posted by MMasa View PostYou have a large bolt pattern 61" cylinder used 1924-1929.
Mark Masa
John
If you need a cam you may want to get it now. I doubt that they will last for much more than a week or so.
MarkMark Masa
www.linkcycles.com
you probably could have traded the cylinder on the forumrob ronky #10507
www.diamondhorsevalley.com
I WOULD have traded you for the correct cylinders, but quite frankly, the value of your cylinders has been GREATLY diminished by the modifications.
MarkMark Masa
www.linkcycles.com
