22JA engine
  • cabanadan
    • Sep 2009
    • 64
    22JA engine
    Just picked up a 22 JA engine. Tried searching and they made a JA engine and not lots of info out there. Is this a cop motor? Fast motor? 61 or 74 CI? there is a casting stamp on primary side 2-18 on it and a circle with what looks like wef cast into it. Does this make it an early or late motor... Any help???
  • 23JDCA 808
    • Jan 2007
    • 688
    From http://www.techsweb.us/hdvin2029.html
    Model 20JA - "A" motor F-head V-twin, 3 speed, electrical system
    A group that specializes in these 1916 thru 1929 cycles: https://groups.yahoo.com/neo/groups/harleyjd/info
    Bill Gilbert in Oregon
    • cabanadan
      • Sep 2009
      • 64
      Techwebus doesnt say if it is a 61 or 74. any help?
        • 6029
        If you have cylinders with the motor; count the number of horizontal fins by the spark plug, and down to the exhaust spigot. A 61" will have 5 fins, and a 74" will have 7 fins.
        • MMasa
          • 1192
          74" was introduced in 1921 so my money is that a 1920 is a 61"
          Mark
          Mark Masa
          www.linkcycles.com
            • 6029
            I thought he said it was a '22.
            • Tommo
              • Sep 2001
              • 1320
              If it left the factory as a 74 it would be stamped JDA surely.
              It still could have been converted at a later date and then you do as Eric says and count the fins to decide
              Peter Thomson, a.k.a. Tommo
              A.M.C.A. # 2777
              • MMasa
                • 1192
                Sorry. My bad. I looked up and saw 23JDCA 808's post and saw "20JA"
                I agree with Tommo. The VIN would have a D in it if it was a 74".
                The base flange stud spacing will tell too. All 1921-23 61" cylinders were small base.
                Mark
                Mark Masa
                www.linkcycles.com
