1919 to 1923 Sport model clutch
  • Venus
    • May 2011
    • 27
    Does anybody know the original thickness of the clutchplates.
    What matarial was used for friction.
    I assumed it would be cork but it is not and the partlist reads "fiber insert".
    I am also looking for a second gear, a mainshaft and a motor sprocket.
    Peter
  • Tommo
    • Sep 2001
    • 1320
    Peter,
    I have NOS clutch plates on hand and they have cork inserts that are 5/32 of an inch thick overall.
    Can't help you with the other bits and no the clutch plates are not for sale.
    Peter Thomson, a.k.a. Tommo
    A.M.C.A. # 2777
    • Venus
      • May 2011
      • 27
      Thank you for your reply, this is usefull information.
      My plates are in good condition but i only need to replace the cork.
      Can you tell me if the cork inserts are pressed in or are they loose or maybe glued?
      Peter Venus
      • Tommo
        • Sep 2001
        • 1320
        They're a tight pressed in fit.
        I've got an article on recorking clutch plates that will save me a lot of typing, I'll find it and put it up here.
        A.M.C.A. # 2777
        • Tommo
          • Sep 2001
          • 1320
          I got this from a magazine some time ago and don't know who to attribute it to.
          I hope they don't mind me putting it up here but it does tell how to recork clutch plates in plain and simple terms.
          A.M.C.A. # 2777
            • Aug 2001
            • 1343
            I have a spare clutch (also not for sale) that I'm trying to get someone to bond clutch material to instead of using the cork buttons. Even if I end up using one less disc it should work better. I've had my sport model for a number of years and the clutch keep getting worse. I'll let you know how it turns out.
            Louie
            YouTube >>> LouieMCman
              • Aug 2001
              • 1343
              picture......
              Louie
              • Venus
                • May 2011
                • 27
                Dear mister Thomson,
                Thank you for the article.
                I found a company in Germany who has already cut the cork and selss on ebay, so that saves me a lot of work (and fingers).
                I will keep you informed about the progress.
                Peter
                • Venus
                  • May 2011
                  • 27
                  also a picture
                  You can see that I am not ready to go on the road yet.
                  But I am getting there.
                  At the moment the bike is being spraypainted and I am working on the engine.
                  Peter
                    • Aug 2001
                    • 1343
                    Sport Model link currently on eBay...
                    http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
                    Louie
                      • 5953
                      Isn't there a more modern material that would do the job better?
                        • Aug 2001
                        • 1343
                        That's what I'm going for Chris. Modern clutch material bonded to the plates beats 132 cork discs in my book!
                        Louie
                        • Tommo
                          • Sep 2001
                          • 1320
                          Louie,
                          If you are changing away from corks you can now get someone with a water jet to cut the entire friction plate out of suitable material at a very reasonable cost.
                          It's amazing what modern machinery and materials can do.
                          A.M.C.A. # 2777
                            • Aug 2001
                            • 1343
                            Good idea, I hadn't thought about that. Although I don't think there's a water jet within a couple hundred miles, It's something to look into, anythings better than making 132 buttons. Thanks.
                            Louie
                            • Perry Ruiter
                              Henderson KJ wanted!
                              • 621
                              This is reminiscent of the late 60s early 70s when people where experimenting with Indian Four clutches with buttons of materials. I think Viton was what was eventually settled on and it worked well ... Perry
