jd frames
  • MMasa
    • 1192
    Harley J Frame ID
    If you can, post closeup pics of the following sections of your frame and I'll ID the exact year.
    Rear axle clips
    Steering head
    Top front motor mount
    From above, the area from the seat post tube back to the upper cross bar between the upper stays.
    Mark Masa
    Mark Masa
    www.linkcycles.com
    • gsottl
      • 216
      Harley J Frame ID : 24 J ID sample
      please find attached pictures of my 1924 Model J frame and the brased-on numberplate.
      • gsottl
        • 216
        stearing head supports on loopframes - changes 1919-1924?
        attached a picture of the stearinghead on the“24 frame. I think the frames with the brazed-on reinforcements were used from late 1919 (maybe also a little later?)
        Were there any changes done to these reinforcements? I have heared something about thicker steel-plates used on the late (1924) loopframes.
        Would be great to get some more information on the headset design-details. I am convinced Mark has more details and more precise information on the introduction of these reinforcements?!
        Best wishes from Europe,
        gsottl
        • MMasa
          • 1192
          gsottl
          I would say that the head reinforcement started in 1920 however it could have been a late 1919 thing. Neither of my 1919 frames has this feature on the neck but all three of my 1920 frames do. While it looks like a brazed on plate, I'm pretty sure that it was a modification to the forging die.
          Mark Masa
          Mark Masa
          www.linkcycles.com
