What Does a "B" Mean in Harley VIN?
  • Buzz Kanter
    • Jan 2002
    • 539
    My 1924 Harley has a letter B stamped as the last digit in the VIN on the cases. Looks original as far as I can tell. Sure am curious what it means. Any help would be appreciated on this. Thanks.
    Buzz Kanter
    [American Iron Magazine Harley Magazine
    • Feb 2003
    • 5353
    On the Injuns it means Battery.......... maybe it's the same with the "other" brand.... Seriously though.......cool bike Buzz. Do you get in a time warp when ya ride it?
    Cory Othen
    Membership#10953
    • 23JDCA 808
      • Jan 2007
      • 688
      Does the B appear to have been struck at the same time as the rest of the VIN? Or is is askew or different depth than the other numbers?
      Bill Gilbert in Oregon
      • 23JDCA 808
        • Jan 2007
        • 688
        they do exist. ...bill
        • Buzz Kanter
          • Jan 2002
          • 539
          Yep, looks a lot like mine.
          Anyone know what the "B' at the end means?
          Buzz Kanter
            • Feb 2003
            • 5353
            Could it be for the piston material? A was for aluminum and B was for iron. Or is that letter designation at the front with JD? Now you got me wondering......... Don't know much about the J Model.
            Cory Othen
            Membership#10953
              • Feb 2003
              • 5353
              Now come to think of it........ the A or B for piston material is surely at the front. Maybe you should quiz Dale there Buzz. I'm betting he might know.
              Cory Othen
              Membership#10953
                • 6018
                1924 was the first year for aluminum alloy pistons (optional). You may be on to something Cory.
                • Buzz Kanter
                  • Jan 2002
                  • 539
                  In a 1924 JD I believe the CA in the JDCA (at the front of the VIN number sequence) indicates the piston material. The B at the end is what I am trying to understand.
                  Buzz Kanter
                    • 6018
                    There was also a JDCA in 1923 but they didn't offer aluminum pistons in 1923.
                      • 6018
                      That's according to the data I have. I believe aluminum pistons were available for earlier models but it looks like 1924 was the first year that they were confidently offered as an option. Tommo would be able to more give a more deffinitive answer.
                      • pete reeves
                        • Nov 2001
                        • 245
                        Buzz.
                        According to the 1922 to 1927 parts book
                        JD. indicates 74cu inch. Generator equipped
                        A. indicates aluminium pistons.
                        According to the 28 to 32 parts book
                        C. indicates heavy duty commercial truck motor.
                        It also says that there is a compression plate specifically for low compression DCA motors, this would indicate that there were two different compression ratios offered on JDCAs maybe the reason for the B after the number?
                        Other reasons could be to indicate the motor sprocket size of if it was supplied with a side car or package truck.
                        Eric.
                        This may not mean that they were actualy fitted in 1923 but 22/27 and the 28/32 parts book lists aluminium pistons for the 23 DCA motors it lists different aluminium pistons for 24/25 motors.
                        Pete Reeves 860
                          • Jul 2003
                          • 1832
                          Cory wins the jackpot!
                          According to original model layout sheet for 1924, the letter "B" FOLLOWING the serial number stands for "Iron Alloy Pistons." However, none were marked "A" or "C" for that matter. Just "B".
                          1923 was not like that and 1925 was not like that.
                          In addition, the 24JDCA12472B bike number shown above was considered to be "Model 24JDCB" with the "A" dropped!
                          Aren't Harley serial numbers fun? The Bible Code ain't got nothing on us!
                          Last edited by HarleyCreation; 03-31-2009, 04:34 PM. Reason: adding to the confusion....
                          Herbert Wagner
                          AMCA 4634
                          • Buzz Kanter
                            • Jan 2002
                            • 539
                            Fascinating (and confusing) info. Thanks so much.
                            I have owned this bike since the 1980s but never really spent much time getting to know it properly. I am hoping that will change now, especially with all this help on this and the Classic American Iron Magazine site at www.caimag.com.
                            Buzz Kanter
                              • Feb 2003
                              • 5353
                              Good trivia to know for sure. It's all about figuring out the puzzle. Again, cool machine you got there Buzz.......
                              Cory Othen
                              Membership#10953
