I'm currently setting up the rear wheel on my '74' Sportster Drag bike. The 'Aluminum' rim is stamped 'Made in Italy' and has the 250 C markings along with the H-D stock numbers stamped on it. This is the correct wheel for this bikes year. The wheel is NOS and came with the original tag specifying the use of a "Goodyear 4.25x18 'All Traction' tire." It also states: "This wheel has a "C" Section Rim. Only taper base bead tire will fit correctly." My questions to anyone who knows are: Am I correct in assuming that I can use the same type tires on this rim as that of the steel rims?? Aren't all the H-D 1950's-80's rims "C" section type?? Can I use standard modern tube and tires on these rims?? Can someone tell me the modern tire size ratings?? I'm looking to mount a new style 5" Goodyear slick on this rim?? The front rim is of same type but in 19". I plan to mount an Avon Speedmaster 325/350 size on the front. Any help appreciated before I plunk down the cash for tires. Also would like to make sure they stay on!!...
...Hrdly-Dangrs
...Hrdly-Dangrs
