My question concerns the Oil Tank Mounting plate used on Big Twins. Is the turned down lip running around the perimeter of this mounting plate 90deg to the mounting surface all the way around on an OEM original? I have looked at several and all have the area bent in behind the battery hold down rod hole on the left side behind the clutch arm. It appears to me this would be a modification for clearance of the clutch arm....
Highlander
Highlander
