Rear stand ID
    • 2025
    Rear stand ID
    Anybody have any ideas. I think it is HD.
    • 2044
    '30-'35 vl
    • JoJo357
      • Feb 2016
      • 3313
      Jerry, it appears to be the later VL stand *1934-36 rear Stand. H-D added another rivet, making 3. on the 'improved' contact brackets & reinforcement sides, as opposed to the 2. rivet 1930-1933 rear stands. *The improved '34-36 stand appears to be one whole piece, as opposed to the '30-'33 two separate pieces.
      *Fat Albert put the 'improved' stand to the test...and it failed! lol
      *1934-36
      *1930-33
      *M.A.D.*
        • 2044
        • Peter Cooke
          • Aug 2012
          • 573
          Dang it! My freshly painted '31 has a 34/35 rear stand. The things you learn...
          • JoJo357
            • Feb 2016
            • 3313
            To quote Freddie Prinze..."LOOKING GOOD". Hey Peter, maybe Jerry Wieland will sell you his '30-'33 correct
            Rear stand? Looks like just a little tweak job.
            #Supercharged 1931 Harley VL. You read that correctly. #harleydavidson #vintagemotorcycle <------
            The DeLuxe: Supercharged 1931 Harley-Davidson VL <-------
            *M.A.D.*
            • Peter Cooke
              • Aug 2012
              • 573
              Thanks JoJo, that's a good looking machine and should go like shite off a shovel with the blower. And I see it has the wrong stand as well so now I don't mind so much!
              • JoJo357
                • Feb 2016
                • 3313
                Yessiree, that '31 bobber is certainly a different animal! As far as the stand goes, it sounds like you're making a...'Stand'. Haha. You'd lose a few points, but you'll have the improved rear stand.
                Good
                Luck Peter with the rest of the build! Can't wait to see the '31 completed!
                *M.A.D.*
                  • 6044
                  Early H-D rear stands were 7/8" 'U' channel. Did that continue into the V series rear stands? Sorry for the sidetrack but wondered if H-D continued that odd/rare channel width up to the '36EL.
                  • Peter Cooke
                    • Aug 2012
                    • 573
                    I'd have to measure to be certain Eric, but I think you are correct. Up to '35VL at least. '36 was different I think.
                    • Peter Cooke
                      • Aug 2012
                      • 573
                      Originally posted by JoJo357 View Post
                      ....it sounds like you're making a...'Stand'. Haha.
                      Ha, good one JoJo. I recently decided I wouldn't mind a luggage rack so I'll add the correct stand to the list of 'things to keep an eye out for'.
                        • 2044
                        '36 VL is a different part # than all others
                        • JoJo357
                          • Feb 2016
                          • 3313
                          You're correct Duffy. The 1936 V's had the one year only 1936 debut knucklehead rear stand. I've changed my past comments from 1934-36 to 1934-35 for future reference. I believe i confused the V rear stand dates with the V front stands, which are 1934-36, per Steve Slocombe's recent front V stand posting. I can't 'stand' when that happens~Haha. H-D customers must have had problems, like the picture J.Wieland posted of the tweaked 1930-33 rear stand. The 1934-35 rear stand was improved, but I imagine H-D thought it was a lot easier and cost effective to just add a welded solid bar across the strengthened new sides, and call it a day?
                          1936 V & Knucklehead Rear Stand. *One year only pictured below.
                          *M.A.D.*
                            • 2044
                            '36 VL is a different part # than all others......1940 parts book
                            • JoJo357
                              • Feb 2016
                              • 3313
                              **Uncle...
                              *M.A.D.*
