J, JD rear wheel bearing rollers
  • 23JDCA 808
    I have a technical question. J and JD owners (1916 thru 1929)
    need individual replacement roller bearings for their rear hubs.
    A stock ‘flat’ roller is 0.490” long by 6.350 mm diameter. (~0.248”)
    First oversize (+0.002”) would be 6.355 mm diameter.
    Where would I look for these?
  • Smarty
    Bill,
    Have you tried Fabercycle ?
    • 23JDCA 808
      I just emailed them. I will let you know if I get a hit. Thank you.
      • motorhead1
        Harley-Davidson part# 9220A.
        It measures .250 x .490 and is the standard size roller for the pinion shaft bearing assembly on '58 and later big twins.
        • 23JDCA 808
          Yes; that should do it. Thank you. ...bill
          • motorhead1
            BTW, they also come in oversize increments of .0002.
