12-32 bolts
  • belmont
    • Feb 2020
    • 138
    12-32 bolts
    I found a bag of 12-32 bolts in my stash and have no idea where they were used. They are 15/16" long, full thread and have a 3/8" hex head. Cad plated and I have 63 of these little beauties to find a use for.
    Anyone have some info on why Harley dealer from the late 30's to mid 80's would have them?
    Thanks for any info on this oddity. belmont
    • 4785
    7/32 -32 is the thread size of the tank top screws for everything from Js to 45s.
      • 8234
      Don't forget 3532-18S, which is "oversize".
        12 x 32 is very close to 7/32 x 32 so they are probably 3532-18 tank top screws. With 6 used on the JD and 5 on the VL you will get through 63 of them quite quickly.
          • 8234
          We may never know, Folks,...
          But I wonder if the 3532-18S, which is "oversize", was accompanied by an over-sized tap?
          How else would you use it?
          • belmont
            • Feb 2020
            • 138
            Cotten, do you think maybe the oversize is 1/4-32 thread?
            I have a 1/4-32 tap that I use to clean the threads for the 70's front brake light switches.
            Thanks for the help on my little mystery. I never thought of 7/32 - 32 as being the same as 12-32. Been out of the machine shop for too long I guess.
            Karel
              Yes the original oversize tank top screw is 1/4-32 although not all the repros may be identical, as 1/4-28 is a standard thread. I think the original 3532-18 were 12-32 as described, and I used to be able to buy old stock taps this size, but now use 7/32-32 which is within a few thou.
              • Tommo
                • Sep 2001
                • 1320
                NOS oversize tank bolts 1/4 x 32 DSCF4300.JPG
                Peter Thomson, a.k.a. Tommo
                A.M.C.A. # 2777
                • belmont
                  • Feb 2020
                  • 138
                  Thanks for all the help on this.
                  belmont
