Seat bracket?
  • belmont
    • Feb 2020
    • 138
    Seat bracket?
    I have had this sitting on the shelf for 30 + years and it is time to find out what it was made for. I can't find a listing in all of my Big Twin, K model, Sportster, or Servi-Car parts books covering 1951 to 1985 years that has this particular design. At almost 10" wide could this be for one of the 165 cc singles? The rod is 3/8" and has 24 TPI on each end for those unique shouldered fasteners. All of the Big Twin and Sportster parts books show the frame mounted Buddy seat as using a bracket that allows easy access to the battery. This one needs a 1" wrench for those shouldered nuts. The 5/16" x 24 thread bolts on it were, as far as I know, used in the late 50's and early 60's.
    Any and all help is much appreciated.
    This gallery has 4 photos.
    • 8248
    Want another one, Belmont?
    I was told it was a 2216-37 "shifter cross shaft bracket", for a right-hand shift.
    (Pictured on page 48 of the '36-'48 Parts Catalog.)
    Chief riders switching to HD might like one.
    • belmont
      • Feb 2020
      • 138
      Thanks Cotten, one of these is enough for me.
      2216-37 crosses over to be 33707-37. Your guess for the bracket seems unlikely, the right hand shift cross bracket bolts are used to mount the engine to the frame, which are 3 1/2" on center. This has nuts spot welded on it that are 5 1/2" on center.
      I don't see how this solid rod with 3/8" x 24 threads on each end that just fits into these shouldered nuts could work as a right hand shifter, you would need bushings for it to work smoothly.
      The mystery continues...
        • 2025
        I think that is a seat bracket to mount a banana type seat to a FLH.
        Jerry
          • 8248
          I won't tell you who told me, Belmont...
          It doesn't make much sense as a seat part either!
          Somebody's gotta need both of them. Huh.
          • belmont
            • Feb 2020
            • 138
            Wheels its been a long time. Nice to see that you are still around. The weather forecast is for it to get above zero for the first time in a week tomorrow, it was -30 this morning. I will try to get to the frame mount buddy seat I have been saving and check to see if the bracket fits on it.
            I would think that Harley made it easier to get to the battery than this setup would be on a Big Twin. You would have to remove at least one of those shouldered bolts to get the seat to flip up for battery access. I have a swing arm frame in the garage and will have to check to see if it all fits.
            By the way am I correct that the circled "F" on the bolt head was a late 50's to mid 60's style?
            Thanks for taking the time.
            • joe fxs fxr
              • Dec 2020
              • 706
              Jerry
              That's what I think - for the boat tail super glides (and sportsters?)
              want to sell it?
              AMCA #41287
              1971 Sprint SS350 project
              1972 FX Boattail Night Train
              1972 Sportster project
              1973 HD Golf Cart project
              1989 Springer Softail project
              2020 Heritage Classic 114
              • belmont
                • Feb 2020
                • 138
                Joe, I think you solved it! The rod and shouldered nuts are different then the ones in your pic. I found a good drawing in my 1971 Big Twin parts book with part numbers 52061-71 for the bracket, 52074-71 for the stud (threaded rod), and 52076-71 for the nuts. My 1971 Sportster parts book shows a different bracket design, Sportster frame was narrower than the FL/FX frame.
                I am willing to sell it all, PM me sometime.
                  • 2025
                  Well I was close - I knew it was a seat bracket! Jerry
                  • belmont
                    • Feb 2020
                    • 138
                    Jerry, do you still go by Wheels? I did go out to the deep freeze today and look at the frame mount seat I stashed so many years ago. It has the same size bracket, but it is just like the drawing in the parts books. Slotted on the tabs and through holes to bolt it to the underside of the seat.
                    Thanks for the help, Karel
                      • 2025
                      Yes Numerous people still call me that. Jerry
                        • 8248
                        So what is this thing, Folks?
                        Thanks in advance,
                        • belmont
                          • Feb 2020
                          • 138
                          Cotten, This is a used 1971 FX Superglide fiberglass "boattail" seat bracket and mounting hardware, see post #8 in this thread for the part numbers. It is missing the 2 bolts and washers shown on mine that fasten it to the fiberglass seat shell. This thing is pretty much a one year only part, the first year for the Superglide. I was told that Harley did make a few 1972 Superglides with the "boattail" seat in black instead of white for 1971. You got a rare piece for a desirable 50 year old collector bike. This thing is shown in my 1971 Big Twin parts book and it may be in a very early 70's FX parts book that I don't have. it was a real hard one to figure out.
                          Belmont
                          • joe fxs fxr
                            • Dec 2020
                            • 706
                            When PM'ing with Belmont I mentioned that I have a FX boat tail fender that I was going to use, but now is just garage art. He was kind enough to measure his seat bracket and mounting hardware and send me detailed dimensions and pictures so I could make one. The other day I scored an original seat for my fender, and that was the impetus I needed to build the bracket. It's basically 2" x 3/16" flat bar, so off the hardware store I went.
                            (Its hard to take pictures while working, so some of these are staged.)
                            I heated and bent the bar over a home made mandrel to get the approximate radius on the bend.
                            The ends have a 1-3/4" radius, which just happens to match one of my oil cans:
                            Cut with a hacksaw and shape with the grinding wheel, files and sandpaper. Then drill holes for the shouldered nuts. Luckily I have a 3/4" drill bit.
                            AMCA #41287
                            • joe fxs fxr
                              • Dec 2020
                              • 706
                              It's starting to look like an original part now. A lot bigger than i expected, too. LOL
                              Drill holes and position the nuts for the fender mounting nuts, and weld them on.
                              A couple light coats of paint, and it looks pretty good. There is a lot of weld spatter on the surface, unfortunately. The factory must have spot welded the nuts.
                              AMCA #41287
