drum brakes
  • davedld
    • Feb 2021
    • 2
    drum brakes
    new builder. need help checking/rebuilding drum brakes. 1970 HD. Harrisburg,York,Lancaster area. any help much appreciated. thanks
  • Architect
    • Dec 2014
    • 283
    Welcome. Please provide more information as to your issue and questions? Stock bike just doing some maintenance? Basket case and not sure how to put it together? Something in the middle? More info, the better the answers. This is the inside shot of the front brake on my '70.IMG_3323.JPG
    • davedld
      • Feb 2021
      • 2
      basket case . in over my head not sure where to start with brakes guess I want to make sure brake mechanics are in working order, also taking bike down to frame. went pretty well little trouble removing swing arm but last step is giving me fits. front motor mount bolts will not give . I got the 2 bolts that go thru the motor case with a little struggle but the 2 thru the frame will not budge. top and rear motor mounts loosened no problem. one last question top right front motor mount bolt fastens to a nut welded on the motor, is that factory ? really appreciate you getting back to me. thanks from a first timer
      • painterdale
        • Oct 2013
        • 423
        I'm guessing Sportster?
        Dale
          • 2024
          Dale
          No FL. The brakes on this bike are very straight forward. Especially if you are using your exploded view parts book. You need to be able to measure the drum, deal with installing linings, arcing/arching shoes and put back together. Jerry
          • Architect
            • Dec 2014
            • 283
            First, you need to go on the Bay and find yourself a Factory Service Manual and a Parts Book. Both are invaluable with directions and exploded views so you know what you are dealing with. Copies are fine if the originals are hard to find or too pricey.
            Second, soak the crap out of the bolts with your releasing agent of choice, maybe a little heat, and be patient. You may need to work it slowly, tight , loose, tight loose, until all the crap gets out of the way. Good luck.
            • painterdale
              • Oct 2013
              • 423
              I was basing my guess on his description of the front motor mount.
              Dale
              • Jcadams
                • Nov 2018
                • 43
                Top right front motor mount says sportster
