1929 model C 500cc facts
  • cotte
    • Aug 2020
    • 12
    Hi
    I have just started to restore a 1929 model C Harley Davidson. I am curious to know how many of the 1929 500cc model where produced.
    All other facts for this model is also welcome.
    The Harley black book shows 1582 C models made that year, so good sales in the first year as for the D model small twin. I restored two 1930C models and found Johnny Sells' book on the 1929-36 45s a big help. Cycle parts are as for the small twins but engine parts are hard to find. I had to make a small batch of head gaskets and probably have a couple left. There are one year parts in '29s and they were made as entry level models, so many have been thrashed and the survival rate is not high. They are not yet big money bikes for collectors. The weak point is the gearbox and clutch from the A and B singles, but not as bad as on the early 45s. At least you don't have the vertical generator.
    • cotte
      • Aug 2020
      • 12
      Thanks Steve for the reply.
      I am just waiting for the second edition of Johnny sells' book to be available.
      My bike is in fairly good condition, except for the paint. It has been repainted at some point and its look terrible and graphics are wrong. So I will get repainted as it was original. The biggest challenge right now is the exhaust muffler. I have learned from my research that I am not the only one with that problem :-). I have the correct muffler so I will have to reproduce some parts for that one and get it renovated.
      • Speeding Big Twin
        • Mar 2010
        • 433
        For 1929 The Legend Begins says 1570 Cs and 12 CMs (magneto) but that book also states that its own production figures from the beginning thru 1969 are not to be regarded as totally accurate. And I don’t see a third model mentioned even though there appears to have been a CE?
        Are the engine and frame original to each other?
        Eric
        • cotte
          • Aug 2020
          • 12
          Thanks Eric
          How do I check if the engine and frame are original to each other?
          /Carsten
          • Speeding Big Twin
            • Mar 2010
            • 433
            Best idea is to ask the previous owner(s) about the history of the bike. If that doesn’t help then you could check the style of frame. When the Model C was introduced it had the same frame as the smaller singles. Steve mentioned the frame head forging number in your other thread.
            Frames were also referred to by Jerry Hatfield in his book called Inside Harley-Davidson. According to Hatfield: ‘These initial big singles used the same frame as the 21 ci singles.’
            Eric
