what is it
  • Shed king
    • Sep 2019
    • 2
    what is it
    I'm currently restoring a single cylinder B model Harley side valve generator model, I have a 1926 frame with a 1929 motor 29B1946 and its coming along ok. I have another bottom end with the engine number A2995 and I was of the understanding that the A model was the overhead valve model ? is this correct the casings are similar but a small difference on the left hand side . Any information would be greatly appreciated.
  • Peter Cooke
    • Aug 2012
    • 570
    This might help.
    • MMasa
      • 1192
      Magneto ignition side valve.
      Mark Masa
      www.linkcycles.com
      • Speeding Big Twin
        • Mar 2010
        • 433
        Welcome to the forum. If the serial number (SN) is authentic it sounds like a 1926 model as opposed to a 1927 model. SNs for 26 model singles began at 1000 and ran into the 8000s. For 27 model singles the SNs began at 9000.
        Model A is magneto ignition SV as Mark mentioned. More info on the sheet below which was posted by another member a while ago.
        Eric
