exhaust cover lengths
  • Omarttentmaker
    • Dec 2009
    • 318
    Anyone out there have a stock set of "slinkys" who could measure their lengths in the extended position? I think I have 2 fronts, and I want to cut one back to fit the rear exhaust pipe on my rigid frame panhead. Any help would be appreciated.
    • 6018
    I notice you haven't had any replies, so I've got to figure no one has a stock set. Personally, I would just cut the rear to fit the pipe, as I believe there can be extenuating factors that would make for variable applications. I think the best solution would be to study period photos, and count the number of coils, or note the appearance of the coils at various bends in the pipe.
      • 5952
      The length of the front differs between Panheads and Knuckleheads because of the different placement of the pipe to frame clamp.
      • Omarttentmaker
        • Dec 2009
        • 318
        Thanks Chris and Eric for your replies. Your idea to count the coils is a good one Eric. And yes, Chris, the front would be shorter for I believe pre-'47 because of the front pipe clamp placement.
          • 4785
          Short fronts also are used with a sidecar. Rears differ from Pan to Knuckle due to the pipe bell, etc.
