I always try to run all the fuel out of my older MCs but I know that I don't get it all. Is there a real good additive to use like Seafoam or something else? Thanks Mike
Fuel additives
I had 3 bikes that had seafoam nightmares this spring-there is no such thing as bad gas cure[maybe beeno]
Duffey, could you share detailis of your seafoam nightmares ? i just started using the stuff last winter,as i've heard a number of people extol it's virtues. Thanks !Steve Swan
27JD 11090 Restored
27JD 13514 aka "Frank"
Not just mine,another shop had me come over to help start a dead bike this spring[he was very ill]-it started and ran for a short distance and died on road with a fried ignition module-we replaced the module and it would not start until all fuel was removed and even the fuel in the cylinders had to be burned out.[sea foam]I see many no starts each year because they think fuel can be cured of old age.I suck the fuel out of my Panhead each spring before attempting to start and mix small amounts of it in each tank of my old beater car till gone.My servicar can start and run on about any crap.Last edited by duffeycycles; 08-29-2015, 10:37 AM.
you could build a retort still . Take fresh gas and distill the ethanol off. You would need a pair of brass ones to try this.rob ronky #10507
www.diamondhorsevalley.com
Just keep the temperature down, Rob!Originally posted by rwm View Postyou could build a retort still . Take fresh gas and distill the ethanol off. You would need a pair of brass ones to try this.
A hot water bath would do. The trick is finding the right kitchenware in the dumpsters for a reflux condenser.
....CottenAMCA #776
My solution is very easy. I just drain the tanks completely and empty the carb bowls on my bikes and start fresh each year.... I never have springtime fuel problems any more.Bill Pedalino
Huntington, New York
AMCA 6755
