Good afternoon Gentleman, We have added a long overdue item to our parts inventory. These are J and JD Main drive gear bushings for mainshaft 2272-25. These can also be used on shaft 2272-19 but need to be shortened. These are stamped like the originals with the inter locking keyway. I made these five thousand over size so you can hone your main drive gear and clean it up if need be. We can shorten the bearings for you if needed for a $15.00 machining charge. Bearings are $52.00 per set plus $3.00 shipping. You can order them by e-mailing me at bob@thegoodoldmotorcyclepartscompany.com and I will invoice you though Paypal.
J, JD Main Drive Gear Mainshaft Bearings
Tags: None
We get a flat rate of $225.00 to solder them on and machine them to fit plus shipping. This includes the cost of the bushing. We will also need your main drive gear along with the shaft to fit. If your main shaft is 90 years old and just on the edge of being scrap. I suggest you replace it. We've got them on the shelf. BobLast edited by Robert Luland; 04-05-2014, 04:41 PM.
Mark, were did I say I had the gear but on the other hand. Get engineering and marketing on the phone! I want a meeting with the BOD on Monday morning, Stat! You got all that Gladys? Yea, I know I forgot to pick up flowers for the wife. Damn it, I got an empire to run! Lol
Sorry Bob. I misread "mainshaft" as "main gear". I was all excited.
MarkMark Masa
www.linkcycles.com
